Use the following procedure to display the OVSDB protocol support for VXLAN Gateway configuration.
show ovsdb config
SWITCH:1>show ovsdb config ================================================================================ Ovsdb Config Info ================================================================================ Status - Enabled Certificate - Installed Private Key - Installed Replication Peer NLS-IP - 192.0.2.3 Replication Local NLS-IP - 192.0.2.2 ================================================================================ Ovsdb Controller Config Info ================================================================================ ID Protocol IP Port 1 ssl 192.0.2.10 6640
